2.5t miss
Old Jan 16, 2020 | 06:29 PM
provident's Avatar
Default 2.5t miss
Running a 2005 s40 with 2.5T, 240k miles. I get an intermittent miss only at 1800-2000 rpm with about 20-40% load (moderate inclines) . I just changed the fuel pressure sensor suspecting that but still there. I plan on changing plugs next. Any suggestions ?
Old Jan 17, 2020 | 08:36 AM
see if you can get the car to produce a DTC code by getting it to miss more frequently - that may tell you which cylinder(s) are missing. Also do you have a code reader that can monitor fuel trim real time? A lot of possibilities here - fuel delivery/pressure, spark (plugs/coil/wire harness), air metering (MAF, O2 sensor, intake/exhaust air leaks). If you do the plugs, inspect the connectors on the wire harness to the coils. Are the coils original?.
Old Jan 17, 2020 | 06:32 PM
provident's Avatar
don't know the car's history so not sure if coils, wires, etc are original, but could be. I do know the plugs are at least 60,000 miles ago. The old code reader is not showing any codes nor were any showing up with vidas last time I was at the local independent Volvo shop. I don't have a reader to give realtime results.
the odd part is the miss is only at a certain load and in a very limited RPM range. give it more or less pedal and it is gone.
Old Jan 23, 2020 | 03:41 PM
doesn't sound like the miss is that severe if there's no CEL. Plugs are due at 60K intervals, and depending on your engine code, you may be due for a timing belt at 240K miles (most are 10 year/120K miles except VIN codes with a 39 which is 15/150K). I'd inspect for vacuum and exhaust leaks which can lean out the mixture and inspect the connectors to the coils to see if there's anything cracked. Go with OEM plugs - more expensive doesn't always work better on Volvo turbos.
Imbackinthe909
Jul 6, 2018 11:12 AM
andrew1234
Sep 21, 2014 10:02 PM
hsettle
2001-2013 model year XC70
Nov 5, 2012 10:17 PM
moneyhungryvolvo
Jan 14, 2012 07:27 AM
johntua1
May 3, 2008 05:37 PM
