2005 S40 2.4 fwd abs light, anti skid, icarsoft
Old Jan 19, 2020 | 12:10 AM
Philb676's Avatar
Default 2005 S40 2.4 fwd abs light, anti skid, icarsoft
Trying to help my mother in law. Abs light and anti skid warning in message center. Icarsoft scan says no signal from left front and sensor. Tried to clear, but blinked and was back on immediately, without driving or doing anything. Replaced sensor and no change. Old and new sensor metered to ~25ohms. What do I check next and what are the common issues?
thank you
Old Jan 23, 2020 | 10:53 AM
habbyguy's Avatar
It would be a bit of a pain, but you need to try to trace out the wiring. I've seen ice and snow stress and break the cables / connectors on ABS sensors. I'd bet dollars to donuts that's what's happening here. Volvo's manual stinks, so there's not much specific info I can suggest beyond that...
Old Jan 23, 2020 | 11:00 AM
Philb676's Avatar
thank you for the response. Really appreciate it and didn’t consider it previously. I will check for broken connections next and report back.
Old Jan 26, 2020 | 01:39 PM
Philb676's Avatar
it worked! Found a nick in the wire between the sensor and wheel well, soldered the broken wire and sealed the repair. Reinstalled and fastened in a couple more places since it appeared the nick was caused by suspension flex after hittting a pothole. Thank you for the advise.
Bg76
May 22, 2019 09:34 AM
Fancie
Sep 10, 2017 01:37 PM
Chris Plinston
Jul 18, 2017 05:59 AM
ranger_00953
Oct 6, 2009 01:02 PM
skibomb
Oct 3, 2009 10:29 AM
