200 S40 Engine Mounts...
Can anyone tell me if the engine mounts on this car can be tightened easily and/or replaced by an owner? Where are they located at? Is there any special tools, etc. that are needed? Thx...
They are so so.
On a scale of 1 to 10 I would say about 7.
One is right off the front of the engine.
One is under the Air filter box.
There is 2 under the car.
Did you ever figure out the problem? I have a 2000 Volvo S40... same problem. Vibration starts at 50 mph... get worse at 65 and stops during decelaration. I was told it might possibly be the tires so I relpaced them with brand new ones today. Same problem. I was told to get an alignment next but I think the struts might also be bad... shouldn't the struts be replaced first?? Please let me know if you figured your problem out. Thanks,
Don Storms
Don Storms
I started having the same problem with 2001 s40 Vibration only on acceleration, 4 new tires balanced and front end alignment doen last week. Also anyone know the cost of motor mount or CV replacement?
i have a 2000 s40 (100k miles) with heavy vibration during idle( as well as during acceleration), and i think its the mounts. Not sayingyour mounts aren't bad, but something else may be contributing to your problem as well...
(That said, what is a fair price for changing out all 4 mounts?)
