2000 s40 1.9t Bad Turbo causing Positive Crank Case Pressure
Hey y'all I think I figured out why I still have a Positive crankcase pressure even after PCV replacement.
Can a Bad Turbo Be messing Up The airflow in the PCV?
I was looking at Both hose ends from the PCV Line that connects to the ptc and the intake, when I connected the intake hose and put my thumb over the Orc end of the hose I finally got full vacuum when I would connect the hose back into the pic port I would lose vacuum again. So then I tested out the Turbo air Duct that connects to the air f
peace562
04-12-2015 01:14 PM
