2000 S40 High RPM
Old Jan 25, 2006 | 10:03 PM
androide016's Avatar
Default 2000 S40 High RPM
Hi i own a 2000 s40 and when i started it from cold I see that the RPM is little bit above 1K RPM. I think isn't normal, what can cause this?
Old Jan 25, 2006 | 11:03 PM
Default RE: 2000 S40 High RPM
Did it stay there even when it warmed up?
Old Jan 26, 2006 | 01:02 AM
gordon368's Avatar
this happened to my first car which was an s40..... does it start ok?
Old Jan 26, 2006 | 09:49 AM
when it warmed up or after run it for about 10 minutes the RPM go down for about 700 RPM
Old Jan 26, 2006 | 09:52 AM
Most of times start ok, but sometimes like when the night was cold the starting don't fell good, in some ocasions i have to start it two times.
Old Jan 26, 2006 | 09:28 PM
I would clean the throttle body and check the coolant temp sensor.
Old Jan 29, 2006 | 03:23 PM
Already clean the throttle body , but the problem still. Maybe it's time to change the spark plugs.
Old Jan 29, 2006 | 06:06 PM
When it is cold the idle will raise for about a minute or two then drop to normal.
You might also want to check fuel pressure and see if it drops all the way to Zero when shut off.
woodlief
Jul 31, 2013 10:33 PM
tromptista
Jan 1, 2013 06:05 PM
leppya
Jun 5, 2011 01:20 PM
thomasas
Mar 30, 2011 06:57 PM
