2000 S40 Security Status Light Not Functioning !
Old Apr 30, 2005 | 01:43 PM
00S401.9T's Avatar
Default 2000 S40 Security Status Light Not Functioning !
Hello I'm a first time Volvo owner,
I recently purchased a 2000 S40 1.9T with remote start. When I purchased the vehicle I noticed the light on the dash was on and blinks at times. After using the Keyless entry a few times to get to know it I noticed the light does not come on at all now.
Does anyone have any ideas on why this light no longer works? I locked the doors, reached inside, opened the door and the alarm does not sound. Is there a valet feature that I'm not aware of? I read through the manual several times but found nothing that helps.
Thank You in advance for any help.
Old Apr 30, 2005 | 02:09 PM
Default RE: 2000 S40 Security Status Light Not Functioning !
Is the remote start function aftermarket?
I will almost bet the remote starter is piggy backed onto the factory system.Then anything could be wrong.
Old Apr 30, 2005 | 07:52 PM
00S401.9T's Avatar
Yes, I believe the remote start is aftermarket.
I tried the factory keyless entry also and nothing turns the status LED on.
Old May 1, 2005 | 01:53 AM
Does the remote starter still work normal?
If something is wrong with it that might be messing the entire system up.
There should also be fuses in the aftermarket alarm system under the dash.
Old May 1, 2005 | 09:47 AM
00S401.9T's Avatar
Yes, the remote starter still works.
I don't have an aftermarket alarm, just remote start.
Also the passenger side door lock is not fully unlocking, it tries to unlock but does'nt make it all the way up.
Old May 1, 2005 | 01:39 PM
That could very well be your problem if the lock isn't opening all the way then the alarm wont set if it is also not locked all the way.Sounds like you need a new lock.
Old May 1, 2005 | 02:16 PM
00S401.9T's Avatar
I tried disconnecting the battery for a couple hours and still no light.
What do you mean by a new lock ?
Could something just be binding ?
Old May 1, 2005 | 08:41 PM
Most likely the lock assembly is bad.
There is micro switches internal in the lock that tell when it is locked.
It might show locked but really isn't.Or the micro switch is bad but is not replacable.
Old May 1, 2005 | 09:20 PM
00S401.9T's Avatar
There is a factory security system on these vehicles, correct?
Is the light that is on top of the right hand front speaker supposed to flash ?
Where can I buy a service manual for the 2000 S40 ?
Old May 2, 2005 | 01:10 AM
Yes there should be a factory system.Yes the light should blink.
Im not sure where to get the manaul.
spintop1
Feb 10, 2014 06:19 AM
Kevin Baker
Volvo C30
May 18, 2011 01:03 AM
fivekampers
Oct 19, 2009 07:04 PM
wagonman
Mar 27, 2008 01:51 AM
