2000 S40 transm fluid
Old Jan 7, 2010 | 09:51 PM
Peter1234's Avatar
Default 2000 S40 transm fluid
Im asking about which transmission fluid I have to use on my 2000 S40. Its recomended to do a flushing to the transm??? And I need to know what are the S and W modes for the transmission and how I use them?? Im new in this forum and that S40 is my first car.
thank you!!! : D
Old Jan 8, 2010 | 09:15 AM
robyne00's Avatar
S is sport mode. W is winter/wet weather mode. When you use "W" in bad weather it will not allow the car to "take off" from a dead stop. It also makes slowing down easier. "S" uses more gas but is good if you're cruising. When neither of these modes is applied, you are considered to be in economy mode, which saves gas.
Old Jan 8, 2010 | 10:27 AM
Lyonsroar's Avatar
S = sport mode = the transmission reaches longer before shifting
W = winter mode = the transmission starts out in higher gear to prevent slipping
I personally flushed my transmission at 90k miles at the dealer. Really it's not that expensive at the dealer and it did make a difference with shifting harshness. If you really want to do it yourself there is a how-to here:
http://s40concepts.net/forum/index.p...sg&th=10506&am
Old Jan 10, 2010 | 06:17 PM
Peter1234's Avatar
Thanks... Well my car is 118.000 so i will use the machine. But thanks for the information and nice to be here in the volvoforum. See you!!!!!!!
christian amezquita
Mar 9, 2015 10:36 PM
mojobaby27
Mar 9, 2015 09:40 AM
mt6127
Feb 4, 2015 10:32 PM
aryanvahedi
Oct 8, 2014 02:26 PM
Helder
Mar 9, 2009 09:24 AM
