2000 S40 brake issue - no fluid from ABS pump to one wheel?
Old Dec 26, 2014 | 07:55 PM
Default 2000 S40 brake issue - no fluid from ABS pump to one wheel?
My 2000 S40 brakes started pulling to the right - so I has my mechanic check for a stuck caliper. he said the caliper looked fine but noticed it was not getting any fluid to the front left wheel. When they took the line off the ABS pump module - again no fluid came out when the brakes were activated... Does it make sense that the pump module could fail or clog to one wheel only or should I be checking sensors etc? Used anti-lock pumps are cheap enough to find but looking to see if anybody has experienced a similar failure.
Old Dec 28, 2014 | 04:48 PM
migbro's Avatar
Can't really help you with the specific question but I can tell you I exercise my ABS systems as often as is practical/safe. Before you do anything you might try this as I think it's possible that the ABS valves can stick. So brake hard on dry pavement in a safe location until your ABS activates. Do this a few times and see what happens.
From your story it appears you may now have one brake line full of air. Your mechanic should not really have left your car in that condition. If you do try my trick and free up your ABS module be prepared for very poor braking action after that until your brakes are bled.
Old Dec 30, 2014 | 02:17 PM
Default Good thought...
Hmmm worth a try. I'm wondering if I should try with/without the ABS fuse in... My thinking is, if the ABS pump and activators are off line the normal pressure from the master cylinder should push through the ABS valves without an interference from the controller...
Old Dec 31, 2014 | 02:49 AM
migbro's Avatar
The blind leading the blind now. Doesn't make any sense to me but if it sounds good to you go for it. You're probably going to wind up replacing the ABS unit regardless.
Old Feb 4, 2015 | 04:24 PM
post mortem on this I ruled out the ABS control module due to the lack of codes and assumed one of the valves just got stuck in the pump itself Too cold out to tear the unit apart etc so I replaced the pump unit with a used part I got for $75, bled the brakes and all is good. Now I have a spare control unit to boot and I may take apart the old pump for a look...
Old Feb 4, 2015 | 10:32 PM
migbro's Avatar
Thanks for reporting the outcome. There's snow on the ground here in New England so I'm giving my ABS a good workout.
jackson2600
Nov 15, 2023 02:04 AM
kennta
1998-2000 model year V70
Jan 4, 2015 05:31 AM
J Dubb
Jun 25, 2011 08:11 PM
mortonight
Jan 23, 2010 08:34 PM
katiejoyful
Dec 12, 2007 04:49 PM
