2000 S40 trunk is stuck won't open
Old Dec 10, 2009 | 12:05 PM
mastceh's Avatar
Default 2000 S40 trunk is stuck won't open
I've tried openning with the remote trunk release and opening manually but it just will not open, what should i do
Old Dec 13, 2009 | 05:10 PM
deucetech's Avatar
Fold down the back seats and climb in the trunk. Most Volvos have another trunk release on the underside of the inside of the trunk. Find it and pull it. If that doesn't do it, it must be jammed. A good strong pull might do it. If not, take it to a shop.
Old Jan 5, 2010 | 10:15 PM
robyne00's Avatar
I have this issue with mine from time to time as well. I was told to unlock the car manually twice, with the interior switch. Sometimes it works and sometimes it doesn't. If anyone has additional info, it would be most appreciated.
Old Jan 9, 2010 | 01:22 PM
robyne00's Avatar
I replaced the battery in my remote, as the trunk would not open manually most of the time, and unfortunately, it STILL doesn't work!!! I will try to find the interior trunk release in the meantime.
Does anyone know what the issue is?
Old Jan 12, 2010 | 02:13 AM
Vivi's Avatar
I unlocked my trunk the other day with my key and it set my alarm off! Why does it do that?
Old Jan 12, 2010 | 06:38 AM
sjamies's Avatar
When trying to open manually, can you hear the boot mechanism 'clicking' as you try to open it? If so, try pushing down hard on the boot, and then try opening again.
I have a 2006 S40 and my boot stops opening from time to time, and this is how I get round it - a hard push down on the boot. Definitely a Volvo flaw!
Old Jan 12, 2010 | 09:36 PM
robyne00's Avatar
I will try your advise sjamies, as I do hear the "click".
I'll let you know what happens!
jwoertz
Sep 5, 2016 02:24 PM
davidchicago
Sep 22, 2011 11:49 AM
Vincef
Mar 18, 2009 08:42 PM
nedflack
Dec 16, 2004 03:09 PM
