2000 Volvo s40 constant battery draw
Old Jan 25, 2016 | 05:24 PM
Alex Stallings's Avatar
Default 2000 Volvo s40 constant battery draw
I just recently purchased a 2000 Volvo S40, runs and drives perfectly. However, if sitting parked somewhere overnight, the battery will be dead.
This is what I know:
The alternator is fine
No electrical systems were left on (glovebox light, parking lights, trunk light, etc)
It has an aftermarket alarm in it.
Any ideas of what could be drawing enough amperage to drain a brand new battery in 24 hours?
Old Jan 25, 2016 | 07:52 PM
Here's the URL for the sticky on the 850 board
https://volvoforums.com/forum/volvo-...g-101-a-42655/
It could be one of several things - a failed switch or relay, fault ignition switch, a short in the voltage regulator or even be the alarm system. The place to start is to see if any of the fuses are passing current with the key off. (there's a small amount of current drawn to power the clock/ecu etc but very nominal (ie .02A ). If you don't see anything drawn through a fuse then you may need to isolate the alternator/voltage regulator etc.
Old Jan 26, 2016 | 08:44 AM
s40_Ontario's Avatar
Maybe your new battery is at fault. Guess you could try disconnecting a lead overnight, reconnect and see how much cranking power you have.
Old Jan 28, 2016 | 06:04 AM
Hudini's Avatar
Aftermarket alarm? It has a built in alarm. Are they not getting along?
davisrf
Jan 13, 2013 11:12 AM
dmkelly1955
Oct 27, 2010 01:36 AM
datderboy216
May 22, 2010 06:42 PM
EnzoRacing
Dec 26, 2009 01:03 PM
jdibber
Nov 13, 2009 07:36 PM
