2000 Volvo S40 ignition canister coupler issues
Old Nov 20, 2018 | 02:46 PM
Marybeth222's Avatar
Default 2000 Volvo S40 ignition canister coupler issues
Hello, does anyone another name for this part? I think a local shop may be giving confusing information.
If you are familiar with it, is it a fairly simple thing to replace?
Thanks, Liz
Old Nov 20, 2018 | 06:38 PM
Hudini's Avatar
Do you have a picture? I ask because there isn't an ignition "canister". There is an ignition coil (2 total). And each one has a connector (coupler). I'm guessing you are talking about the coil connector because they do tend to get brittle and crack with age. On mine I made sure to push the individual female wire leads onto the male coil leads. Although the plastic housing the female leads (the coupler) tends to break you can still securely connect each individual wire without fear they will work loose. The tension on each wire is sufficient to hold the wire onto the coil.
Old Nov 24, 2018 | 02:42 PM
check out Volvo PN 30864977 - its the wiring harness that can sometimes fail on the Gen1 S40s
bluefrontier@att.net
Sep 26, 2017 12:09 PM
Ricardito
Aug 14, 2012 08:29 PM
qstyle
Feb 16, 2009 09:17 AM
Floaterdave
Jan 27, 2009 11:46 AM
vwagon
Dec 28, 2005 01:37 AM
