2001 s40 cabin filter
Old May 6, 2008 | 02:59 PM
costa993's Avatar
Default 2001 s40 cabin filter
Just wondering where canI find the cabin filter and how often should it be changed? Thanks
Old May 6, 2008 | 03:59 PM
djerikd's Avatar
Default RE: 2001 s40 cabin filter
It's above the front, passenger footwell. You'll have to remove the soundproofing panel (two screws) to see it. It's held in by a small (approx) 2" x 10" panel that is removed by opening a small plastic clip.
I believe they recommend changing it every 15K miles, but don't hold me to that. Personally, I do it twice a year.
Be glad you've got an S40. It's one of the easiest cars to change the cabin air filter and ten-timessimpler than doing it on my '98 V70. If it takes you more than three minutes, you're doing it wrong.
Old May 13, 2008 | 05:36 PM
fosh100's Avatar
you are lucky if you can do it in three minutes , xc90,s60,v70 takes about 10mins all in, the 04 - s40, v50, c70 and 07 c30 take about 20 mins, have to remove a control module and remove about six big multiplugs.
Old May 23, 2008 | 03:27 PM
tabes's Avatar
I actually was on a tight budget and just removed it washed it and let it dry for a couple days and reinstalled it seems to work just fine.
Old Mar 12, 2011 | 02:35 PM
Bestefar's Avatar
where is the small plastic clip - thanks
Old Mar 12, 2011 | 02:42 PM
Bestefar's Avatar
Default s 40 2001 cabin air filter
Wondering where the small plastic clip is that you have to remove to get at the air filter compartment?
debargha
Feb 24, 2015 10:46 PM
nigel_miguel
Jan 7, 2012 05:09 PM
bluemagicbus
May 17, 2011 07:18 AM
edahlgren
Oct 21, 2010 06:24 PM
Ahmed
Mar 28, 2008 04:22 PM
