2001 S40 Center Dash Cover Removal
Old Mar 3, 2012 | 08:20 AM
Athilla's Avatar
Question 2001 S40 Center Dash Cover Removal
Hi all,
I would like to remove the front cover off the center console of my dash (actually just the panel where you find the 3 ***** for them fan, temp and vent position controls). There is creaking noise from behind the cover and it's driving me crazy Does someone have a diagram/know the steps?
Thanks very much
Anthony
Old Mar 9, 2012 | 11:25 AM
lukaspanic's Avatar
I think it differs a little if you have automatic climate control or manual climate control. I have automatic and here is how I get it off:
There are small openings with 3 horizontal slots on each side of the panel. The panel is clipped in with a plastic clip in the bottom most slot on both sides. Shove a small flat head screw driver straight in it to lift the plastic tabs and then use a 3rd screwdriver to carefully pry the panel out from the side. To reinstall just push it in.
The panel above (with the vents) and the panel below (cupholder etc) have screws holding it in behind the climate control panel.
trs80
Jun 25, 2011 02:05 PM
rit72
Mar 30, 2010 10:59 PM
AMoore
Sep 2, 2009 07:09 PM
tr_car_nut
Jan 19, 2008 09:37 AM
spelton
Jul 23, 2006 01:17 AM
