2001 S40 VVT gasket replacement
Old 05-03-2016 | 12:45 PM
kstinmb's Avatar
Default 2001 S40 VVT gasket replacement
2001 S40 1.9L with 99K miles.
There's some oil on the timing belt end of the engine block and I suspect the gasket under the VVT actuator/solenoid is leaking. Can I simply remove the four bolts and swap the gasket? Does the new one need to be prepped (coated with oil) or just installed dry? Do I need to adjust anything after re-installing the actuator?
Thanks,
-stephen
Myrtle Beach SC
Old 05-03-2016 | 01:25 PM
ES6T's Avatar
New one goes on dry. Nothing special needed. However, the source is likely either the cam seal or the VVT unit itself. The solenoid gasket is worth a shot though since its a lot cheaper and easier.
Old 05-04-2016 | 06:14 AM
Hudini's Avatar
And watch the torque on the bolts. I somehow managed to stretch one bolt to almost the failure point. Luckily I did not strip the threads in the aluminum cam cover. It could have been a defective bolt. I don't know.
tr_car_nut
01-15-2017 10:33 AM
JP R
02-16-2013 08:53 PM
Hopper
1998-2000 model year V70
09-15-2012 11:48 PM
darylorage
06-29-2012 11:38 PM
russellsv40
06-02-2011 01:02 PM
