2001 Volvo S40 T1.9 A few codes...
Arrggghh...I swear I'm going to go outside and put a bullet in this thing...
Changed FPR, MAF, Spark Plugs, and Coil Packs and Accelerator Cable
Now its pulling the following codes
P142
P101
P139
P507
The car will run for a second then shut off, run for a second then shut off. Usually on about the 3rd or 4th try. It'll stay lit, but will shut off again.
Any ideas? Or at least on deciphering the codes specifically?
Thanks all,
Steve
P142
P101
P139
P507
Thanks all,
Steve
First, disconnect the negative battery cable for 30 minutes. Then clear the trouble codes with an OBD-II code reader. Then check this small hose that goes between the throttle body and intercooler.
Now try to start it and see if the codes return. I would also consider this for the bottom O2 sensor: Oxygen Sensor Spacer (CEL Boss)
MrMugottu850GLT
Feb 8, 2013 01:25 AM
