Another Transmission Gone Wrong! Bleh. Check Codes Already. Few Questions?
Old Feb 8, 2013 | 01:25 AM
MrMugottu850GLT's Avatar
Default Another Transmission Gone Wrong! Bleh. Check Codes Already. Few Questions?
Hey guys, first post on this forums. Im a big car nut and this is my first volvo!!!
its a 1993 850 GLT automagic 90k miles
was sitting in the yard for two year when i picked it up, didnt run, bought for 300.
Bought new battery, change fuel pump and filter. and now its brand new!
haha well kinda.
Anyways to get to what i need help with. The car runs great. just the dam transmission.
Yes i have the blinking light. it also stays into higher gear when i am driving it around.
I believe its on limp mode.
I have opened and cleaned the PNP and it seems to work a little better. i ran code threw A1 and got 1-2-2 and also 2-1-1.
S1 Solenoid code
and transmission ecu code? i believe.. not positive.
i have been doing a lot of research and now i just need a little more advice and direction on changing the solenoids. i herd it is best to do all three. S1S2 (part# 6843783) and SL (part#6843784.
where are these solenoid located?
and am i heading in the right direction?
sorry im a nub when it comes to volvo.
Thanks in advanced!
also to add. Now after i cleaned the PNP it actually goes into 1st when all warmed up. it just doesnt go into 2nd. i will try and take apart the PNP again and clean it better with sand paper and what not to see it will do anything.
also. When i put it into reverse. It gives a hard shift like action into reverse.
I will check motor mounts.
lmk if u have any input. thanks!
v1lcins
Dec 27, 2011 05:41 PM
leoinvegas
Dec 2, 2011 07:41 PM
dobrosailor
Jan 16, 2010 10:21 PM
qstyle
Feb 17, 2009 11:57 PM
mccreadys4
Dec 22, 2005 12:42 PM
