2002 s40 check engine code P0015
Old Oct 10, 2017 | 06:10 PM
mrford55's Avatar
Default 2002 s40 check engine code P0015
got a code P0015 camshaft position actuator B does this mean solenoid is bad.need help
Old Oct 11, 2017 | 08:31 AM
pierremcalpine's Avatar
Welcome to the P0015 club! You'll find more info than you can shake a stick at on this topic simply by googling "Volvo v40 (or s40) p0015." You'll also see that many of us have been very frustrated by this code.
Root cause, small oil passages clogged up preventing VVT from shifting from it's "lock" position on the cam.
Most likely cause, clogged VVT. Other things to check - wiring of solenoid, resistance test of solenoid (I think 7-9 ohms is range), clogged solenoid, and wiring to the cam position sensor on the othe side of engine.
Some claim to have had some success by using ATF or Seafoam in the oil for 500km prior to next oil change...I may resort to this next myself as I really don't feel like replacing my vvt again!!!
Armenian
Dec 16, 2017 11:16 AM
tamark69
Mar 8, 2013 08:07 PM
bsobo
Dec 7, 2010 03:42 PM
jfavs19
Feb 3, 2010 08:49 PM
costa993
Feb 14, 2009 07:35 AM
