2003 s40
Old Feb 10, 2005 | 01:37 PM
medik's Avatar
Default 2003 s40
On the dash , sometimes light comes on with an X over the car image. What is this telling me ? Is it safe to drive ?
Old Feb 10, 2005 | 03:43 PM
mercury320's Avatar
Default RE: 2003 s40
Bad battery in your key? That icon is the "immobilizer" icon. If the light is coming on while the car is running, you may have a bad key, bad battery in your key, or a short in the cars electrical system (most unlikely). It shouldn't run (fuel pump kill i believe) if that light is on, but I'd imagine it will continue to run normally as long as it was started with the key signal present.
Old Feb 10, 2005 | 08:42 PM
Either the module in the key is bad or the immoblizer antenna ring is bad.If your car doesn't start and that is flashing then it is not getting signal from the key.
biliouschee
Apr 9, 2007 11:04 AM
Genna
Mar 11, 2007 07:48 PM
muja
Feb 28, 2007 03:26 PM
medik
Jan 20, 2005 03:58 AM
