2003 Ticking
2003 Ticking
I have a 2003 s40 with 104,000 miles. I am the only owner of the car. It does a ticking sound like a clock when I am just starting it and running it for a while. I don't know if the sound stops later, I haven't paid attention. I think it does stop at some point or else I would notice it like I do at the beginning.
I have had different comments about what it is. One was something about the oil, the other, I am not sure.
I realize that I am being very vague, but maybe this is an obvious problem or at least common.
Any ideas what this could be and what repair costs would amount to--or if repairs would be necessary?
Thanks
Thanks
You describe an exhaust leak. On my 2001 one of the nuts on the exhaust manifold studs would back off causing a sewing machine sound when the engine was cold. As the manifold heated up and expanded the noise would go away. The fix on a cold engine is to remove the exhaust heat shield, then reach behind the engine with a ratchet and tighten all the nuts to spec. To keep it from happening again use a stainless steel stop nut. Do not use the NYLOCK type stop nut as the nylon insert will melt.
I had the same problem, and the above fixed it.
Success
I finally had my garage address this issue. I printed out this thread and asked them to check if this was the problem. It was and they fixed it. Thanks, so much.
