2004.5 S40 center console
Does anyone or has anyone been successful in removing the radio face plate on a new 2004.5 S40? I want to install a FM modulator for XM since the radio reception isn't what I would expect.
If you need help in removing any of the other panels or parts around the center console, I've been there, done that.
Thanks.
Thanks.
RE: 2004.5 S40 center console
Hi there Basically to remove the plate by pushing on the two tabs that are behind the plate, I have added an image to show there to find the two retaining tabs, these can be pushed using either a small screwdriver or a hook. once one side is out its alot easier to remove the other side. If you still have trouble let me know
Cracker39
02-11-2014 06:48 PM
