2005 S40 2.4i Ignition Switch
Old Aug 29, 2013 | 06:16 AM
Ystersaag's Avatar
Default 2005 S40 2.4i Ignition Switch
On Friday my S40 2.4i wouldn't start an displayed "Key Error Try Again", on the display. I called a Volvo dealer I know, explained what the display says and they said that I might need to change the ignition key switch and if that doesn't work maybe the steering lock module. The problem is I'm on a tight budget so is it possible to get a switch and module from a "scrapped", car or is there any other place I can get the items except from the dealer?
Old Aug 29, 2013 | 09:09 PM
ES6T's Avatar
A used switch will work, SCL is programmed to the car though.
Old Mar 9, 2014 | 03:39 PM
WilmetteVolvoGuy's Avatar
Default "key error - try again" shows on dash display
Had this problem today on my 2005 V50 wagon (same as S40 car). I saw another post that said to tap on key with hammer and thought it was crazy, but guess what it worked. I used the plastic handle of screw driver to tap on the key while it was in the ignition slot in the on position. There must be a build up of dust and dirt in the switch that is loosened up by the taping. Not sure how long it will work but it beats towing it to the dealership which would surely equal a $1K plus tab. Thanks for the other posts
Ricardito
Aug 14, 2012 08:29 PM
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
