2005 S40 2.4i Manual Transmission
I recently completed a transmission flush on my Pontiac G6. Now my wife wants me to do a similar job on her '05 S40. Problem is, I don't even know where to start as the cars are completely different. It was easy to find a filter kit and my Pontiac used common Dexron VI auto fluid. On a manual Volvo, the only information I was able to find after hours of searching online is that the fluid type is MTF 97309-10.
I take it that's a Volvo-only fluid that I'm likely not to find in any other retail environment? What does it cost? What about the filter/gasket kit?
Any ideas would be greatly appreciated.
I think your talking two different transmissions, one manual and automatic?
Operation number: 43105-2
Special tools
999 7301 Spanner
Tool number:999 7301
Tool description:Spanner
Tool boards:43
RemovalNote! Removal steps in this procedure may contain installation details.
Remove the left front wheel. Refer to: Wheels
Warning! Be prepared to collect escaping fluid.
Special Tool: 999 7301
Torque: Oil level plug, transmission, 35 Nm
Torque: Oil drain plug, gearbox, 35 Nm
Follow the instructions regarding transmission lubricant Refer to: Lubrication transmission
Perform oil transmission Refer to: Transaxle oil
Installation
To install, reverse the removal procedure.
Special tools
999 7301 Spanner
Tool boards:43
Installation
I'm sorry, I don't think I made myself clear on the post.
I'm speaking only of an '05 S40 with a manual transmission. The auto transmission is from my Pontiac, which I completed the flush before with no issues. Also, the pictures to your response thread are broken.
I do appreciate your response though. Any bit of information would be greatly helpful.
It still doesn't work for me, but I'll try it again from a different computer. It could be the java plug-ins.
What kind of fluid do you recommend using? The owner's manual simply states "MTF 97309-10". No clue what that refers to. . . No luck finding it out on the Internet.
pistorman
Jun 23, 2013 11:37 PM
leanned
Sep 28, 2012 10:37 PM
ouyangcui
May 2, 2007 05:05 PM
