2005 s40 2.4l5 cranks , starts and then stalls out
Battery
I have a battery jumpstart that also tell how charged or how much bolts it gives off and with the car off it’s reading perfectly fine at 12.4 volts my dash said “immobilizer see Manuel”
If your immobilizer is keeping the car from starting, it's because it's not recognizing the key(s). It sounds like something bad happened to your car that caused the alarm to go off and the immobilizer to lose its memory.
As long as you have the immobilizer problem, the car won't start (don't know if that can be the cause of your other symptoms). I'd suggest doing a search on immobilizer in this forum to see if you can find any good advice on how to proceed... Otherwise, it's an expensive trip to the dealership.
dondo3 (06-23-2021)
nachocheese03
12-12-2017 03:26 PM
