2005-S40-Power System Failure-alternator
Old Oct 22, 2011 | 10:24 AM
ivanprki's Avatar
Default 2005-S40-Power System Failure-alternator
Hi, I am trying to turn off the system failure light and battery light, My alternator die I bought new one and replace it, it work perfectly fine, but the warning light stay on, I try to disconnect battery didn't help. Any help?
Old Oct 22, 2011 | 12:08 PM
Hudini's Avatar
Get an OBD-II scanner and erase the code. Do you have access to a scanner? Looks like this:
Obd-II - Harbor Freight Tools
Are you in the US? Parts stores here like Autozone will have them available for you to borrow to check the codes and erase them for free.
Old Oct 23, 2011 | 09:19 AM
ivanprki's Avatar
But this is not check engine light, I have obdII, this is warning light!!! and battery light.
Old Oct 24, 2011 | 10:29 PM
Hudini's Avatar
Oh, misunderstood you. Are you sure it's fixed then? You might try disconnecting the battery for 10 or 15 minutes to see if that resets anything. Just a guess.
Old Oct 25, 2011 | 08:17 AM
ivanprki's Avatar
I did try with the battery, didnt work out, the alternetor is working normal, I am driving car for a weeks.
Old Oct 28, 2011 | 01:52 PM
Hudini's Avatar
I feel for you. I'm having interior lighting issues and can't seem to find what's common to the system.
Here's a bump ttt.
luke8_8
Jul 1, 2023 11:19 PM
marcm1
Jul 21, 2021 11:17 AM
mcnaught82
Feb 14, 2019 07:02 PM
jakeb826
Jul 7, 2010 07:27 AM
