2001 T5 Alternator/Power Failure Issues
Old Jul 2, 2010 | 10:25 AM
jakeb826's Avatar
Default 2001 T5 Alternator/Power Failure Issues
My 2001 S60 T5 has recently begun losing power (a/c shutting down, no acceleration, etc) while driving. I have good battery power and wonder if it is the alternator or a computer code issue. Any thoughts? Is an alternator replacement something an average guy can do with all of the other components in the way or should I drop the cash for a mechanic job? Should I have the codes checked first?
Old Jul 5, 2010 | 11:53 AM
SVTfocusO3's Avatar
It may be your voltage regulator on this year, which can be done without removal of alternator. You can do alternator though.
Old Jul 6, 2010 | 09:47 AM
jakeb826's Avatar
Thanks for the reply SVT. After checking Alldata, it seems that there is a service bulletin covering the same issue. Does Volvo generally cover these issues, even though it is so far out of warranty (84k miles) or am I on my own? Thanks again for the info.
Old Jul 7, 2010 | 06:23 AM
cb1313's Avatar
Default Altenator
The alt. went out on my 2003 C70 at 81,000 and I had to get towed home. I dash lights started to go nuts and then the car went dead.
I changed it myself with a Autozone part. You might as well change the serpintine belt while you are there. I did the work myself.
Cb
Old Jul 7, 2010 | 07:27 AM
SVTfocusO3's Avatar
No, they probably will not if you do not have a service history.
DanSC
Jul 5, 2013 08:34 AM
jasonthaynes
Dec 2, 2012 05:32 PM
ivanprki
Oct 28, 2011 01:52 PM
kosmoscanyon
Dec 16, 2008 12:39 PM
