2005 S40 Trunk Release and Rear Plate Lights Don't Work
Old Sep 7, 2016 | 10:12 AM
RDP's Avatar
RDP
Default 2005 S40 Trunk Release and Rear Plate Lights Don't Work
My rear plate lights are not working and the trunk release does not work either. It doesn't matter whether I try to use the remote or the electric release on the trunk itself. The emergency cable release does work.
I'd previously assumed the trunk release was from being rear-ended a couple years ago, but when I couldn't relicense the car because the plate lights were out and replacing them didn't help I figured it might be something in common between the two.
So, here's what I've done:
  1. Visually checked all fuses.
  2. Replaced the plate lights.
  3. Replaced the trunk wiring harness, part number 8697604-A.
  4. Rechecked all fuses with a continuity tester.
My next thought is to check the next wiring harness up the chain, but I haven't found a manual for the vehicle or any information about it, so I thought I'd ask here and see if anyone had other ideas or if I should just tear into it and see what I find.
Thanks.
Scott V
2001-2013 model year V70
Jul 21, 2013 02:28 PM
RobertMoon
Apr 22, 2011 06:28 PM
volvo-s40
Mar 31, 2011 03:26 PM
enoble
May 29, 2010 03:51 AM
cyclekarl
May 8, 2009 11:32 PM
