2006 S40 - ABS light
Old Jun 19, 2013 | 08:58 PM
npeltier's Avatar
Default 2006 S40 - ABS light
Hello all,
I replaced the front left cv axle and hub assembly on my 2006 S40 2.4i. Now my ABS light is on and the warning message "ABS/Anti-skid service required". I replaced the corresponding speed sensor (because it was relatively cheap and hoping for an easy fix). That did not help.
Any suggestions? I'm hoping it's not because the hub was pressed in incorrectly. Is that possible.
Thanks
Old Jun 19, 2013 | 09:19 PM
s40_Ontario's Avatar
The hub with the gear like teeth have a very close tolerance to the ABS sensor. You might want to compare it to the other side.
Old Jun 20, 2013 | 07:45 AM
npeltier's Avatar
There is no tone ring. The hub assembly is one piece with the bearings sealed inside.
Old Jun 20, 2013 | 09:57 AM
ES6T's Avatar
Aftermarket hub? It could be wrong, or not fully pressed in.
Old Jun 20, 2013 | 10:04 AM
npeltier's Avatar
I used the Timken HA590323
Old Jun 20, 2013 | 12:18 PM
ES6T's Avatar
If its fully pressed in, it can only really be the hub (assuming the code is for that side)
nealeas
Mar 24, 2018 09:59 AM
Scott V
2001-2013 model year V70
Feb 8, 2014 06:46 PM
sportgoofy
Jan 10, 2014 12:11 PM
piv15
Nov 3, 2012 07:56 PM
robohopar
Sep 27, 2007 11:37 AM
