2006 s40 volvo dtc
Old May 11, 2010 | 11:15 AM
danielvolvo's Avatar
Default 2006 s40 volvo dtc
hi i m new at the forum i own a 2.4l volvo s40 , it was made in 2006 , and it has been working pretty well since i bought it but today i have the check engine light on , the codes are :
-a11a- a10b-250a
could someone tell me what do they mean and how can i fix it ?
thanx and bye
Old May 13, 2010 | 03:56 AM
Mad Matt's Avatar
Here is a master list of Volvo DTC's...
http://www.matthewsvolvosite.com/for...ic.php?t=10758
The codes you mentioned are no where to be found. How did you get them? If you get the codes read via OBD II at any indie mechanic or autozone (usually free) with a generic reader we can probably get you going in the right direction or if you go to Volvo they will read the DCT code and and tell you what's wrong and charge you for it.
Old May 14, 2010 | 04:12 PM
i actually am a auto tech , and i get those codes with my scan tool , those are specific volvo codes but i dont have the definition thanx a lot
Old May 16, 2010 | 04:07 AM
Mad Matt's Avatar
-a11a- a10b-250a
thanx and bye
Got it for you. But I can't find anything regarding the A11A code.
*Diagnostic trouble code (DTC) information ECM-250A
Condition
The engine control module (ECM) receives information from the heated oxygen sensor (HO2S) about the fuel/air mixture at different loads. The diagnostic trouble code (DTC) is stored if the engine control module (ECM) registers that the fuel/air mixture deviates too much from target lambda value, leaving the long-term trim in one of its limit positions.
Substitute value
-None.
Possible source
Upper limit
-Air leaks in the induction system.
-Air leakage in the exhaust system.
-Low fuel pressure
-Damaged mass air flow (MAF) sensor
Lower limit
-Oil level too high.
-Contaminated engine oil
-Leaking injectors
-Damaged EVAP valve.
-High fuel pressure
Fault symptom[s]
-Deterioration in performance
-High fuel consumption.
*Diagnostic trouble code (DTC) information ECM-A10B
Condition
The engine control module (ECM) communicates with the alternator control module (ACM) via a standardized serial communication method, Local Interconnect Network (LIN).
The diagnostic trouble code (DTC) is stored if the engine control module (ECM) detects interference in communication with the alternator control module (ACM).
The diagnostic trouble code (DTC) can be diagnosed when the ignition is switched on.
Substitute value
-The alternator control module (ACM) charges at a fixed voltage of 13.8 V.
Possible source
-Contact resistance and oxidation in the terminals
-Short-circuit between the LIN wiring
-Open-circuit in the LIN wiring
-Internal fault in another control module in the same part of the LIN network
-Damaged alternator control module (ACM)
-Generator with a charge regulator not intended for LIN communication installed.
Fault symptom[s]
-The "Generator not charging" warning lamp is lit when the engine is running.
Old May 16, 2010 | 07:21 PM
thanx a lot for helping me ! i know it is hard to find those codes and you did it thanks again , hey do you think it is possible for you to tell me where did you get that info ?
thanx anyway
Old May 17, 2010 | 12:15 AM
Mad Matt's Avatar
No problem man.
I asked around and a guy from another forum sent me this. I'm assuming it's from either VADIS of VIDA or possably any other DVD based manual that a repair shop would have.
You can pick up a copy of VIDA or VADIS on Ebay for pretty cheap but I'm not sure how legit they are. I've heard they work but I've also heard they're boot leg copys. It's too much money for me to test it out. But if you got the extra cash laying around, it might be worth it for you.
http://cgi.ebay.com/ebaymotors/VOLVO...motiveQ5fTools
somedude
Jun 11, 2012 06:34 PM
AutoNaut
Nov 11, 2009 07:54 PM
AutoNaut
Nov 11, 2009 12:32 PM
gordo
Mar 23, 2009 07:35 PM
USSEnterprise
Oct 3, 2006 06:33 PM
