2006 C70 DTC code 0170 ?MAF?
Old Jun 10, 2012 | 11:21 PM
somedude's Avatar
Default 2006 C70 DTC code 0170 ?MAF?
Hi I just joined - first volvo and might just be hooked
Car making a weird humming noise at idle for a day or two (not on initial start but rather only after engine gets hot on freeway)... no change in performance or gas mileage... then it threw the above mentioned code ( also 2 others: specific fuel lean & random misfire) which I have just reset and the car still runs fine...
From what I read on OBD official website it looks like mass airflow could be the cause???
Just curious to ask if any of you all have had this similar situation and if so was it the MAF? And if so how was the repair - just plastic stuff electrical connectors etc easy 15 minuter or not so much?
thank you in advance
Old Jun 10, 2012 | 11:45 PM
somedude's Avatar
Of course any other advice/ideas on the code ( BTW the other one was P2187) is appreciated
Old Jun 11, 2012 | 03:25 AM
MSGTUSMC's Avatar
OBDII Code P0170 - Fuel Trim Malfunction Bank 1 | Engine-Codes.com
Old Jun 11, 2012 | 03:35 AM
MSGTUSMC's Avatar
P2187 System lean idle bank 1.
Clean MAF, throttle body, check boot connector from PCV metal pipe to engine. Spray throttle body cleaner around intake manifold with engine running, detect vacuum leak.
Old Jun 11, 2012 | 06:34 PM
somedude's Avatar
^ thanks
seems like MAF is in common and it's only a $100 something part... yeah weekend fun... I'll try to post an update
leslied123
Mar 8, 2012 12:50 PM
danielvolvo
May 17, 2010 12:15 AM
JimXOC
Apr 19, 2009 10:31 PM
mddavis
Jul 19, 2007 02:36 AM
Epr7339
Jan 6, 2007 12:25 PM
