2006 Volvo S40 2.4i Oil Pan
Old Jan 15, 2019 | 07:45 PM
Zippy83's Avatar
Default 2006 Volvo S40 2.4i Oil Pan
Hi All,
I am in the process of replacing the PCV Oil Trap on my 2006 Volvo s40 2.4i, and thought it would be a good idea to clean out the oil pan. Looking under the car it seems like that I would need to drop the AC compressor before I could get to the oil pan. Am I looking at this right or is there a way to get the pan off without getting to drop the AC Compressor?
Also should I clean it out?
Thanks
Zipp
Old Jan 16, 2019 | 06:49 AM
ES6T's Avatar
Correct, you need to unbolt the compressor. You can leave the lines attached though, it will move out of the way enough to access the oil pan bolts without completely removing it.
Old Jan 17, 2019 | 07:15 AM
Zippy83's Avatar
Thank you.. Will do!!
Dan Ok
Sep 25, 2019 05:41 PM
Newport_j
Aug 21, 2019 11:32 AM
k1s40
Mar 28, 2019 07:20 AM
NEWVOLVOUSERNEEDSHELP
Engine & Internal
Aug 19, 2016 08:28 AM
froberts37
Mar 6, 2013 09:55 AM
