2010 Volvo S40 horn won't stop, lights on
Old Aug 5, 2018 | 08:57 AM
faith99's Avatar
Default 2010 Volvo S40 horn won't stop, lights on
Drove car thru pressure washer all of a sudden my check engine light came on hazard light started blinking air condition kept jumping off and on. I parked my car and stop engine then my horn when off and would not stop. What does this sound like?
Old Aug 5, 2018 | 11:38 AM
habbyguy's Avatar
Did this happen driving through a "normal" car wash, or did you pressure wash the engine compartment?
If the former, it's unusual, but it sounds like a few drops of water hit a strategic location in your computer system, and is causing all sorts of havoc. The good news is, it should dry out (here in Arizona, that might take a lot less time). ;-)
If it's the latter, you really shouldn't pressure-wash electrical components and/or connectors. They operate on very low current, so water mixed with dirt, oil and who knows what - getting into the connectors - or worse, inside the computers / modules will cause lots o' problems. If you are lucky, it'll dry out, though it might take hours / days (depending on how well any doused modules are sealed). The bad news is that dirty water inside an electronic module can disable it until it's removed and laboriously cleaned. Or sometimes, replaced.
Good luck though - hope it was just a stray drop of water that's already evaporated.
Old Aug 5, 2018 | 04:49 PM
faith99's Avatar
Thank you! I left the vehicle in a parking lot will go and pick up tomorrow.
Old Aug 5, 2018 | 10:37 PM
Hudini's Avatar
It sounds like "BEEEEEEEEEEEEEEEEEEEPPPPPPPPPPP" Sorry bad joke. I hope it just needs time to dry.
strelnik
Feb 6, 2016 07:14 PM
Rocket 442
2001-2013 model year XC70
Nov 23, 2014 03:54 PM
tomecsi
Oct 8, 2011 12:25 PM
MyS70GLT
Aug 10, 2007 09:33 PM
tommyv
Sep 17, 2005 05:54 PM
