About cabin air filter
RE: About cabin air filter
It is under the Dash on the Passenger side of the car. Remove the 2 or 3 Phillips screws holding the panel up under the dash and remove. Then look at the bottom of the climate box. You will see a long skinny panel that looks like it is clipped in. It is about 1 1/2 to 2 inches wide and about 8 to 10 inches long. It goes from the dash when you look at it foward. If you push and unclip the panel it will come down. Then you can slide it out and remove the pollen filter.
ORIGINAL: kastenc
How about the cabin air filter for a 2005 S-40? I hear it's behind the gas pedal, and probably the dealer has to do it. Sound right? When I use the A/C, it smells like a furnace that hasn't run for a while. I figure it needs a new filter...
Pay special attention to the nuts holding on the gas pedal, they love to strip themselves out.
