Air Conditioner stops blowing cold
Old Aug 21, 2019 | 01:55 AM
Jjjtread's Avatar
Default Air Conditioner stops blowing cold
My air conditioner stops blowing cold intermittently. When it stops blowing cold I turn it off for awhile then it will be cold again.
Old Aug 21, 2019 | 11:37 AM
sounds like the compressor clutch gap may be too wide or your evaporator may be icing up not allowing air to blow through. Does it only happen on hot humid days?
Old Aug 21, 2019 | 05:42 PM
habbyguy's Avatar
I'm thinking the same thing mt6127 is. Just look at the AC compressor when it's NOT blowing cold, and see if you can tell if the very front part of the pulley is stationary or not. If it IS, chances are it's the "gap thing", which can be a good bit of news since there are some truly cheap easy fixes for it. The easiest way to see if that IS the case is to wait until it's not blowing cold, and then verify that the front of the pulley IS stationary, then (carefully!) tap the center of the stationary part with a broomstick or similar tool. If the clutch engages again, and you're blowing cold air, you know to "fix the gap thing" (look it up on this forum - lots of info).
Old Aug 22, 2019 | 12:20 AM
Jjjtread's Avatar
Default AC intermittently stops blowing cold
No, it is not during hot humid days only. Thank you very much!
Old Aug 22, 2019 | 10:15 AM
I'd start by checking out the compressor clutch. What happens is over time the clutch wears and the gap grows from .03mm to about .06-.08. This causes it to slip slightly which builds up heat and as it heats up, the solenoid loses its pull so the clutch disengages. Once the clutch cools off, it starts working again. Most shops will simply recommend installing a new compressor (complete with clutch) but there are shims in the clutch which can be replaced to correct the gap. This can be done without removing the compressor on some models which saves opening the system up and the time/expense of properly recharging the system.
tnvolsvo
Jun 4, 2012 07:41 AM
Dennis Bor
May 30, 2011 11:14 AM
volvoDT
Jul 23, 2010 03:28 PM
solarman
Sep 18, 2009 07:06 PM
ATL_S80
May 24, 2008 12:32 PM
