Alternative radio setup on S40
Old May 28, 2012 | 10:11 AM
SlikRick's Avatar
Default Alternative radio setup on S40
I know there's been queries into this, but has anyone actually found a feasible alternative radio setup for the 2004.5 and up S40s? One that would be amenable to iPod and iPhone adaptation?
Thanks in advance.
Old May 29, 2012 | 11:45 PM
nmikmik's Avatar
Is the use of the I-device the main reason for your query?
If that is the case you can add some hardware to remedy the issue like :
products
that of course if the stock radio does what you feel it should.
Old May 30, 2012 | 05:31 PM
ddwengineer's Avatar
Default 2005 s40 ipod connect
Has anyone come up with a method for connecting ipod to 2005 s40. Crutchfields, bestbuy, and 3 independent stereo installers in town say it cant be done. something about 2005 only year for optical antenna??
Old May 30, 2012 | 11:07 PM
AutoNaut's Avatar
You can get an FM modulator that connects to the antenna. The S40/V50 antenna connector is not a standard antenna type. However, you can use a 9V battery connector (Radio Shack) and make a connector. I haven't done it myself but I have seen where others have. Swedespeed Forums - XM Commander Install, Plus I found the missing AFM
Also, the Dension Gateway 500 connects to the optical MOST bus that is used in these cars. However, I believe you need the Premium sound system with the CD changer. Swedespeed Forums - Dension GW500 Install... HOW TO DIY
The Grom Audio connects to the optical MOST bus.
Swedespeed Forums - How to integrate "GROM MOST" AUX/USB/Bluetooth/Ipod/MP3/etc. unit
Stan
There are threads on Swede Speed where someone relocated the ICM display to the overhead console and installed an aftermarket stereo in its place.
Old Jun 11, 2012 | 09:29 PM
vonsean's Avatar
I spent a lot of time also trying to figure out a way to my ipod/iphone to play through my 2005 S40 and after researching a few different options including having something installed (not possible because of the waterfall-like dashboard) and fm modulation, the best solution was a C. Crane fm transmitter. (C. Crane FMT Digital FM Transmitter with AC Adapter - 57 bucks off amazon)
I had tried iTrip and a few other fm transmitters that were really terrible and because I live in a rather large city, hardly any of the stations were clear. But the C. Crane fm transmitter is pretty powerful and you can easily open it up and turn up the transmitting functions to broadcast at I think three times what an iTrip (or comparable fm transmitter) would be legally set up for.
I just attached it with velcro strips to the underside of the my seat so it's out of sight and it works great, was cheap compared to getting fm modulation done and for the most part, it works without radio interference.
tito0352
Sep 29, 2009 08:12 PM
Beardog
Dec 25, 2008 10:37 PM
S40goalie
Jan 12, 2008 06:51 PM
pilot60378
Sep 29, 2006 10:15 PM
snoboarder_mike
Jul 2, 2006 10:55 AM
