Antenna replacement
Old Sep 14, 2011 | 05:30 PM
ecr's Avatar
ecr
Default Antenna replacement
My daughter has a 2004 Volvo S40 and she went through a car wash and forgot to turn the radio off. Her antenna bent and I ordered a replacement mast. It was very easy to remove the bent mast and once we turned the car on it released the cable. But installing the new antenna is not working. The cable will not grab and we have turned the radio on and off repeatedly. We can hear the motor running so I am assuming it is working properly but it will not grab the cable. Does anyone have any advice?
Old Sep 18, 2011 | 09:26 PM
Keep trying. Usually you have to bend the tip a little one way or another so it will slip past a ledge it is catching on inside the antenna assembly. It's a pain sometimes but keep working at it. It might help to poke it in and out until you fell it get past the ledge in there. Once you're past it you can turn the car off and watch it pull it in.
bsobo
Apr 20, 2010 08:18 PM
alecw81
Jan 7, 2009 05:22 PM
wellman
Sep 30, 2008 07:07 AM
PE**2
Mar 17, 2008 05:30 PM
fast850r
Jul 27, 2007 09:32 AM
