assistance needed please
Old Apr 12, 2009 | 07:50 PM
jermat's Avatar
Default assistance needed please
ok 2000 s40, behind the driver rear tire theres what looks to be a fuel pump assembly of some sorts. is this the main pump or a pre-pump simialr to the older 240 series? i can not seem to find any information on this part. my problems with vehicle seem to point to a faulty fuel pump, or a fouled timing belt. im leading to the pump assembly as its a very noisy thing, can actually here it pumping or clicking.
Old Apr 12, 2009 | 08:33 PM
That pump is for the fuel evaperative system.
Old Apr 12, 2009 | 09:07 PM
jermat's Avatar
ok thank you tech , also would this thing possibly be a cause of a rough idle and "stumbling under load" symptom ? seems the noise i here comes from this apparatus. at present im cleaining IAC and replacing the little hose from IAC to intercooler, after reading the awesome writeup at s40concepts.net, seems its a very cheap place to start, and hell who knows i might just get lucky and dodge a fuelpump bullet
Old Apr 12, 2009 | 09:15 PM
NO that will not cause that.
That pump only works at certain times when the car is running.
Bascially it puts the fuel tank system under pressure to make sure there is no leaks.
macsfamily
2001-2013 model year XC70
Dec 3, 2012 04:58 PM
75ohm
Feb 26, 2008 08:25 PM
miwachiru123
Feb 2, 2008 11:55 AM
Psaboic
Dec 18, 2007 07:33 PM
Psaboic
Mar 1, 2007 02:42 PM
