battery cable hot
Old Aug 23, 2015 | 08:48 AM
mrford55's Avatar
Default battery cable hot
i got 2002 s40 pos cable is hot . cable now the coating on the cable cracking off
any body know why
Old Aug 24, 2015 | 08:37 AM
heat in a wire/connection means there's resistance - usually a sign of bad contact or corrosion. Try removing then cleaning off the post and crimp connectors then retightening. You could have some broken wires which would suggest replacing the cable itself. I'd also suggest measuring your voltage at your battery terminals with the engine running just to verify the alternator is putting out 13.4 to 14.5V (just confirm you are not overcharging due to a faulty voltage regulator)
Old Aug 24, 2015 | 04:12 PM
mrford55's Avatar
thanks
dejr
May 7, 2012 10:13 PM
rntmgr50
Nov 29, 2007 06:13 PM
beardo265
Sep 27, 2007 09:24 AM
MLRc70
Dec 20, 2005 12:12 AM
