Battery/Not Starting Question
Hey everybody. I'm new here. My wife and I purchased an 01 V40 earlier this year and have an issue that I was hoping someone could help with. (I posted here because I figured S40 forum gets much more traffic).
A few weeks ago the wife left the headlights on and it started draining the battery. Well, after having it recharged and continuing to struggle with it in the hot heat down here in SC, we decided to just replace it. We replaced it and the electrical systems seem to be working fine now, however when we go to start the car, it will not crank. Everything sounds just exactly like it is supposed to in terms of turning over, etc.....it just won't crank.
I have heard the immobilizer could be the issue, or maybe we need a new key, etc. I see the immobilizer light on along with all the other lights when we turn the ignition on and try to crank it. It isn't on any other times than that, if that helps. I'm just not sure what to do without spending a ton of money. Things are a little tight right now and with just having purchased the new battery, we're hoping to save as much as possible.
Anyhow, I really appreciate any input you can give.
Thanks!
Chris
Thanks!
Chris
imaitland
10-09-2012 11:54 PM
rideagiant
09-10-2009 07:56 AM
