Blown head gasket??
Old Apr 21, 2016 | 09:54 PM
S40power's Avatar
Default Blown head gasket??
I just picked up a 2001 S40 that the PO said had a blown head gasket. I haven't had a chance to tear it apart yet because of my schedule, But it doesn't seem like the head gasket is the only issue. It spews coolant out of the right side of the motor causing it to lose all o it very quickly. It also looks like it has coolant in the oil and oil in the coolant. Does this just look like a totally messed up head gasket? or something else?
Thanks!
Old Apr 22, 2016 | 10:33 AM
its possible it overheated due to a hose or overflow container which took out the head/head gasket. You'd need to see where the coolant is leaking out - ie at the seam of the head/block or elsewhere. If you decide to do the head gasket, best to have a shop dye test the head as well for cracks, and inspect the block's freeze plugs and other coolant paths.
shai_kino
Aug 20, 2014 06:45 AM
Reid
Feb 13, 2011 10:01 PM
buckethead
May 8, 2009 10:13 PM
Volvo V70R
Jul 31, 2008 06:44 PM
volksnut
May 20, 2007 05:58 PM
