Brake light intermittent
Old Jun 6, 2007 | 06:55 AM
Gordon's Avatar
Default Brake light intermittent
Issue with rear NS brake light. Will only work intermitently, occassionally goes off and then back on again after taking a corner (coincidence?).
Can't see any issue at the light unit itself, what could be causing this, where else can I look?
Old Jun 7, 2007 | 01:28 PM
billofdurham's Avatar
Default RE: Brake light intermittent
This is one of those tricky faults, now you see it ,now you don't.
The last time I had one like this the positive contact in the bulb holder had been bent slightly and so was making an intermittent contact. Other than that make sure that the negative contact, which actually holds the bulb in place, is not out of round. This could cause an intermittent contact on the earth (ground) side.
Old Jun 7, 2007 | 02:24 PM
Gordon's Avatar
Bill. Thanks for the info. I will have a look this weekend to see if any of these suggestions will work.
Old Jun 9, 2007 | 03:07 PM
Gordon's Avatar
OK the brake lights are all working fine and permanently now.
The brake light warning light on the dash is permanently on....
nealeas
Mar 24, 2018 09:59 AM
hammer1234
Sep 6, 2011 06:48 AM
andyandersson
Sep 22, 2010 09:25 PM
sp0104
Jun 12, 2007 05:16 PM
