A/C could blow better
Old Jun 13, 2012 | 08:59 AM
S40 in Fla's Avatar
Default A/C could blow better
I checked my A/C charge and it is perfect. Wondering if I should change out my squirrel cage blower? Do the vanes clogg up, does the fan motor itself weaken? Just lookin for ideas before I open the fan compartment up. S40 is 11 years old, here in Florida, it gets a lot of work.
Old Jun 13, 2012 | 09:34 AM
Have you changed the cabin filter yet?
Old Jun 13, 2012 | 11:26 AM
S40 in Fla's Avatar
No, but I did pull it and shook it out.
Old Jun 13, 2012 | 11:40 AM
Remove it and run the system and see if the air flow is better. If it is time for new filter. Also are you running it on recirc?
Old Jun 14, 2012 | 07:22 AM
S40 in Fla's Avatar
Good idea, will try that later today. Yes I run it on recirculate occasionally, no difference in air flow though. Few months back, I did have some crap spitting out of vents, maybe some insulation or something from fan box?
Old Jun 14, 2012 | 10:20 AM
You should feel a difference between recirc and non. Maybe the recirc motor is not working.
Old Jun 15, 2012 | 04:10 AM
S40 in Fla's Avatar
I removed filter and yes, air flow is a little better. Also, when I turn on recirc, I feel and hear no difference, but I think it does shut off fumes from outside. Gonna order a new charcoal cabin filter today. Thanks.
Old Jun 15, 2012 | 05:11 AM
You should still hear a difference between recirc and non. It will also drop the inside temp about 12-15 degrees using the recirc.
Old Jun 15, 2012 | 05:30 AM
Lifesgoodhere's Avatar
Ither there is something blocking the recirculate door -- an animal perhaps. Or the electric actuator is malfuncting, or it could be a ton of other things.
use a mercury thermometer and stick it in the center vent, close all other vents and make the air only come out of the vent you have the thermometer stuck in. Put a/c on recirculate and somewhere between low and medium.
have car and a/c running with windows closed. You should have ~40-45 degrees blowing out of the vent on a ~78 degree day. I like tuning that (by adjusting the freon charge) and get 35 degrees.
Old Jun 16, 2012 | 07:38 PM
S40 in Fla's Avatar
Will try the thermometer test and get back to you.
Turbovolv85023
Jan 3, 2008 08:13 PM
JohnS4
Apr 7, 2007 12:33 PM
c70r
Feb 7, 2006 03:25 PM
boostedbrick
Jun 7, 2005 01:55 AM
cecilvaliant
Jan 27, 2004 04:41 PM
