in cabin air filter has anyone changed?
I was told that the gas pedal has to come off, how dificult is it and what to expect?
Please help with any advice from do I have to disconect the battery? And what to expect after removing the gas pedal what kind of connection is under it.[:-]
Thanks for you help
[align=left] [/align]
Thanks for you help
RE: in cabin air filter has anyone changed?
Don't believe everything people tell you.
Use the search function on this and other Volvo sites, to easily find the required info.Also the user manual shouldhelp.
It is really easy to change the filter...and if you mess with the gas pedal, you are not even warm!
Enjoy the reading.
Enjoy the reading.
ORIGINAL: Costy
Thanks for you help
[align=left][/align]
Thanks for you help
The cabin air filter is held in by that case-cover that should have 3 screws that have 7mm heads to the best of my memory. I recommend you have one of those flex-drive extensions on a 1/4" driver.
You will have to deflect the filter a little to get it in there but as far as I can tell, it should snap back into proper shape.
Good luck man!
B
According to Alldata, it can be done, but it will be such a bitch to get to the 3 screws holding the cover in place. I took the cover off and pulled the filter out with pedal in place, but decided to remove it to put new filter in just so I didn't have to bend the filter so much.
B
B
ORIGINAL: Costy
Thanks Brian I think in about one month I will give it a try right about the time my baby girl will be borne.
Costy
Costy
B
