Can you completely disable the security on a 2000 V40?
Old Oct 10, 2009 | 02:27 PM
DougNGainesville's Avatar
Default Can you completely disable the security on a 2000 V40?
I am considering the purchase of 2000 V40. The car runs great but sometimes the car will not turn over to crank. We think the microprocessor in the key is bad or something is up with the ignition disabler. If you wait several hours, the same key cranks the car right up.
I would like to have a mechanic completely disable the security system and/or the ignition disabler. Is this possible?
Old Oct 10, 2009 | 04:53 PM
Not that I know of.
Old Oct 10, 2009 | 05:35 PM
Lyonsroar's Avatar
Check bad battery or immobilizer antenna ring.
Old Oct 11, 2009 | 07:40 PM
We don't think the battery is the issue, wish it was. I am betting on an issue with the antenna ring or key. It sure would be nice to disable the entire security system.
I had similar issue with a Toyota but we were able to totally disconnect the security system.
Sometimes low-tech is the best way.
Old Oct 11, 2009 | 08:15 PM
Lyonsroar's Avatar
You're not going to find anything low tech on cars nowadays! Everything is computer controlled.
Old Oct 17, 2009 | 08:26 PM
We changed out Neutral Safety Switch and pray that is it since the computer showed no immobilizer codes and battery was working well.
Old Jun 29, 2012 | 11:40 AM
toolmanmax's Avatar
Doug, I am have the same problem with my V40. Did the neutral safety switch fix your problems? Thanks!
JamesO84
Feb 28, 2015 05:36 PM
hardwareruss
Nov 9, 2013 10:44 AM
izeus9
Oct 25, 2010 03:00 PM
koster
Oct 11, 2009 08:19 AM
rhody
Jun 4, 2006 02:46 PM
