car stalls throwing 10 codes (S40)
Old Nov 20, 2012 | 06:04 PM
playbios's Avatar
Default car stalls throwing 10 codes (S40)
so i have a 2001 volvo s40 im new to forums and i am having several issues with my car
its throwing several codes (p0303,p0304,p0171,p0505,p0507,p0335,p0036,p0237,p 0107,p0102)
car takes two turns of the key to start
once it starts up it idles high at around 1,100 for a few seconds then levels off
runs fine until it gets up to temperature and when the ac is turned on>
i have replaced the iac, replaced the vacuum hoses, replaced the spark plugs, the map sensor, fuel filter, checked that the vacuum was working correctly, cleaned the pvc valve thoroughly, changed the oil, oil filter, cleaned the MAF
should i buy a new MAF or could it be something else
and the check engine light is always on i hear its a common thing on the s40
PLEASE HEEEEEEELLPPPPPPPPPPPPPP!!!!
mattsoltesz
Oct 6, 2011 10:29 AM
automatic
Nov 26, 2010 03:00 PM
al_ngl
Nov 3, 2010 10:32 PM
trooperone
Oct 14, 2010 05:47 PM
