Car stallsout on starting after being refueled
Old Oct 6, 2017 | 02:17 PM
Newport_j's Avatar
Default Car stallsout on starting after being refueled
Sometimes at a service station after refueling my 2002 Volvo s40 I will start the car and it stalls out. I try again and get the same thing.
I can eventually get it started (on the third or fourth attempt) after pumping the accelerator, but this is awfully inconvenient and it has never happened before,
Also after I get the car easily started and pull up to a stop sign and wait it then stumbles when I accelerate. This stops after a few minutes.
I am not sure what is going on or even if the two incidents are related.
Any help appreciated. Thanks in advance.
Old Oct 7, 2017 | 09:19 AM
firebirdparts's Avatar
i believe you are stirring up some water.
Old Oct 20, 2017 | 11:02 AM
Newport_j's Avatar
Could you elaborate on that I am not following you thinking.
Respectfully,
Newport_j
Old Oct 22, 2017 | 06:16 AM
Vida's Avatar
[QUOTE=Newport_j;452365]Could you elaborate on that I am not following you thinking.
Respectfully,
Does the engine stall right away or does it seem to be running out of gas? Bogging. If so he meant when you got gas water may be in you gas tank. Don't get gas if you have a gas truck filling the tanks at the gas station, it stirs the gas with water.
Old Oct 26, 2017 | 07:57 AM
Newport_j's Avatar
Actually it stalls right away. Also if I get it started and then if I drive say a mile and stop at a stop sign it will stumble when I accelerate away from the stop sign. The problem does not occur after that.
I have A Volvo 2002 S40.
Respectfully,
Newport_j
Old Oct 26, 2017 | 08:52 AM
I believe when you buy fuel, you are stirring up some water that is in the bottom of your fuel tank. You will need to add something to the tank intended to increase the solubility of water in the fuel. You can buy it at the auto parts store.
Old Oct 26, 2017 | 10:56 AM
Oodlemi's Avatar
Is the CEL coming on?
rspi
Mar 31, 2011 03:21 PM
TheGambit
Jan 21, 2009 11:49 AM
minnesotagrown187
Oct 13, 2008 07:04 AM
velovolvo
May 1, 2008 05:49 PM
