Catalytic Converter - newbee
Hello all,
I have a 2003 Volvo S40 with 68K and recently the check engine light came on and off but mostly on (usually when fuel tank is low and on a cold day). I took it to a repair shop and they said that the catalytic converter is bad and would cost $1400 to replace. The car is in California.
How do I know for sure it is the cat and not something else? the car is running fine and gas mileage is normal. If it is the cat, do you know of a good after market branch that is California certified that you would recommend?
Thanks in advance!!!!
If it's the cat here you go,
http://www.magnaflow.com/02catalytic...ayproducts.asp
Might be the o2 sensor?
