CEL Code
Old Dec 20, 2005 | 04:28 PM
Bummer's Avatar
Default CEL Code
Okay so i got a cel code and i'm hoping i can fix the issue that is causing the code to pop up. Well i scanned it at AutoZone and their scantool said that there were two codes except i was only able to read one. I suppose that they are both related but anyhow can someone tell me what P0128 is and what would cause this code to be thrown? TIA
Old Dec 20, 2005 | 09:05 PM
Default RE: CEL Code
All I can find is coolant temp sensor out of range.
Old Dec 20, 2005 | 10:03 PM
Bummer's Avatar
what does that mean? How can I fix this?
Old Dec 20, 2005 | 11:30 PM
Either the coolant temp sensor is bad or the thermostat.
I would replace both to be safe. Plus the sensor is easier to get to once you remove the upper thermostat housing.
Old Dec 20, 2005 | 11:32 PM
S Forty208's Avatar
I have the same problem and have an appt. for fix it. The local dealership says they replace both the thermastat and sensor to assure the problem is fixed. I was quoted 229.00 total at Volvo in Salt Lake City.
Old Dec 21, 2005 | 03:22 PM
Bummer's Avatar
Thanks! I will def look into this. Thanks again. How long ago did you get the CEL S Forty208? BTW if I wanted to do this myself, what kinda hassle am i looking at? or is it just a simple set of steps. Also I erased the code after the last scan and the light has not come on since, it seems to be happening only when it's freaking cold in the mornings. TIA!
matt01
Jul 23, 2012 11:12 AM
rmmagow
Jul 1, 2006 09:40 AM
migkam
Jan 30, 2006 11:52 PM
tabasco
Nov 22, 2005 04:42 PM
migkam
Sep 26, 2005 11:11 AM
