Central locking stopped working after disconnecting battery
Old Aug 8, 2023 | 10:59 PM
NPK's Avatar
NPK
Default Central locking stopped working after disconnecting battery
So, i bought this S40 -02 1.8L and everything was working fine, no issues, changed the VVT, did the timing belt etc etc runs great but then when i loaned it to my little brother and the fuel pump died when i was at a parking area of a store, he decided that it'd be a good idea to disconnect the battery but i said ill go tap the FP and it should come alive for a bit, when i went to remove the backseats he had already disconnected the battery, so i told him to reconnect it since as we all know electric fuel pumps kind of need electricity to work so after a little tap on it we were on our way to buy a new one, afterwards when we parked i noticed neither of my key fobs worked, tested the batteries, had them tested if they sent signal, all was good, plugged in my autocom and it shows two keys should be "paired" with the module and the data shows everything should be okay but nothing happens when i try to use the fob, i can use the central locking from within the car with the central locking button. But i am running out of ideas since i've looked and looked but cannot find any clues as to whats the issue, anyone else experienced anything like this?
Old Aug 11, 2023 | 06:07 PM
habbyguy's Avatar
Sounds like the disconnected battery caused the car to "forget" the two fobs. Just find how to program "new" fobs (lots of DIYs and videos) and try that.
Old Aug 14, 2023 | 01:00 AM
NPK's Avatar
NPK
Sadly the first S/V40's do not support reprogramming without the special diagnostics tool which is a bummer
JadysV
Volvo C30
Jan 31, 2022 12:47 PM
S80Baby
Aug 2, 2017 07:58 AM
5potoilburner
Nov 14, 2016 03:27 PM
calmab
Mar 12, 2014 10:47 AM
bigtown
Jun 9, 2012 08:44 PM
