Changing Oxygen sensor
Old Oct 17, 2008 | 02:44 AM
rgmendoza's Avatar
Default Changing Oxygen sensor
I have a 2001 Volvo S40
i had the codes pulled and i was told i need to change the oxygen sensor bank 1 sens 1
i bought a replacement. I was thinking of changing it myself. would anyone know where i would be able to locate that sensor?
i have access to a car lift so getting under wont be a problem i just need to find it, or some instructions
it would be greatly appreciated.
Old Oct 17, 2008 | 07:50 AM
Default RE: Changing Oxygen sensor
You will change it from the top. If you look down from the back of the motor you should see it in the exhaust. It will be the top sensor.
The wiring goes to the firewall under a long black cover.
Old Oct 19, 2008 | 04:18 PM
rgmendoza's Avatar
thanks, i really appreciate the reply
you were right, i found it and changed it with ease
Old Nov 22, 2008 | 08:39 PM
mobman's Avatar
So what tools did you use bud? I am thinking of doing this as well. Btw. did you buy an OEM O2 sensor or those cheap ebay universal ones?
soduku007
Oct 7, 2019 04:01 PM
habbyguy
Nov 10, 2014 07:01 PM
aruizdelhoyo
Jan 22, 2009 04:46 PM
