Little help please.
Old Aug 2, 2008 | 09:45 PM
I_ride_neon's Avatar
Default Little help please.
First off I want to say hi to everyone. I am new here and just bought my first volvo. It is a 2000 s40 1.9t auto. It has 77,000 on it. I am familiar with turbo setups but not with volvos. So my first question is what kind of boost does it run stock? How much can I run on the stock engine safely?
Old Aug 2, 2008 | 09:46 PM
Default RE: Little help please.
I read the turbo is only good up to 14 psi. Is that true? Is there any other great cheap mods that should be done? Anything I need to look out for? Another thing. I used the light washer blade things (not sure what you call them) and now one of them is stuck in the up position.
Old Aug 2, 2008 | 09:47 PM
It wont go back down even if I try to push it. Any input on that? Well thanks guys hope to learn alot from you! Oh yea this forum reminds me alot of the dodge forum. Makes it easy for me to use .
I also see you guys have the same problem the dodge forum has with long posts.
Old Aug 2, 2008 | 11:40 PM
The headlight wiper motors are common to go bad. If you want you can unplug it and reset the arm. I would only run max 12 PSI on your turbo. It is a small turbo.
Old Aug 2, 2008 | 11:44 PM
How much would you say its running right now at stock? How many psi is the motor good for? And what would you recommend for a filter upgrade? They seem to be expensive. Any cheap ones out there?
Old Aug 2, 2008 | 11:54 PM
5-7 now max I would say witha bigger turbo 15 or so. Go with a K&N panel filter.
Old Aug 3, 2008 | 12:25 AM
I am going to throw a aftermarket blow off valve, the k&n then turn it up maybe 3 or 4 psi. Will this hurt the life of my car or hurt anything in anyway? I wil also throw in a boost gauge to make sure I stay around 10 or less.
Old Aug 4, 2008 | 11:16 AM
S70driver's Avatar
Changing the boost on any stock car can damage it and hurt it in the long run. It is putting more stress on all parts.
Old Aug 4, 2008 | 02:56 PM
Well Here I am from my point of view. My stock neon can do 8psi to problems. The car does not come with a stock turbo. But the srt-4 neon runs 16psi all day easy. With the right tune and turbo you can run 20psi+. That car comes stock turbo. So I assume that because this motor on the volvo comes stock turbo it to is a built motor that can handle the boost. Am I wrong to think that? Thanks
Zachary
Old Aug 4, 2008 | 05:06 PM
S70driver's Avatar
They are not truly "BUILT" motors no. They have a small turbo that can't handle huge amount of boost. At least in your models case you have a small turbo.
Old Aug 4, 2008 | 07:03 PM
I would stay at 10 or below.
Old Aug 5, 2008 | 07:28 AM
mcguij1's Avatar
You have a 12t mistubishi turbo on your s40...you can get a manual boost controller and put the boost up to 12psi without any cel's or problems. The stock boost setting on the 12t is 7-8 psi. If you're going to go past 12psi you should be prepared to run into some problems unless you do some other modding.
Old Aug 5, 2008 | 11:14 AM
jrgillespie630's Avatar
From: Cincinnati, but somehow ended up in Milwaukee
May I ump in and ask how exactly you would go about boosting your Turbo to the 9-10 PSI mark?
Old Aug 5, 2008 | 09:29 PM
jordaninabox's Avatar
Someone want to give me their Subaru stock WRX turbo for 90$ should I do this?
Old Aug 6, 2008 | 07:24 AM
mcguij1's Avatar
you cant just start taking turbos and such off of jap cars and putting them on your s40, if you wanted a rice burner you shouldnt have gotten the s40...for turbo upgrades with your s40 you can upgrade to the mitsu 14t turbo which is a direct bolt on...or you can get a 16g which would need a new flange for the turbo and definitely new exhaust....
jrgillespie- you would need to buy a manual boost controller and you can adjust your boost accordingly as long as you have a boost gauge.
Old Aug 7, 2008 | 08:57 AM
  #17
Hudini's Avatar
You will also need to have your engine's computer tuned for the higher boost. If you boost it higher than the boost tables in the computer allow, you may run too lean and blow the engine.
I wonder just how much boost the stock fuel injectors can handle? Of course a rising rate, boost referenced fuel pressure regulator may do the trick without ecm tuning. I'd think a CEL would still be set if the boost gets too high.
Old Aug 7, 2008 | 10:42 AM
  #18
mcguij1's Avatar
with the s40's the cel will typically come on after you pass 12psi boost. I alot of guys have put there 12t's up to 12-15psi boost, but this isn't recommended, the 14t turbo can handle 15psi okay...Usually when guys put the 14t on they don't mess with the fuel injectors, but when you go up another turbo to the 16g hybrid that guys are getting, then you need to uprgrade your injectors..
Old Aug 8, 2008 | 07:04 PM
  #19
ORIGINAL: mcguij1
This is my school car. My neon will smoke any volvo on the road. Thats why I got the volvo. I wont want to race and beat a slow car. I need more power for the highway and passing. The car is slow. I know all about turbos... Blah blah blah. The turbos you are talking about are for kids.
Old Aug 8, 2008 | 07:07 PM
  #20
ORIGINAL: Hudini
Good call. I found a place I am going to get my ecu tuned at. I hope I would not need to upgrade the injectors and fuel system on a car that comes stock turbod. That would be pathetic. Neon stock ecu and stock injectors with a walboro 255 and a rrfpr I was running 13psi no problems. I may install a wideband just to make sure. Thanks for the tip.
